Old 04-09-2014, 07:03 AM
jlwdvm jlwdvm is offline
Default 1" gap too much?
I set my new wheels and tires under my 69 firebird to get a WMS-WMS measurement to get a Strange 9" ordered. I'm using a Ride Tech 4-link. I set the wheels with a 1" gap to the fender lip and got a measurement of 58.5. Does 1" seem too much...should I go a little wider?
Old 04-09-2014, 07:46 AM
Track Junky's Avatar
You wont know until you drive it. If it doesn't rub and it looks decent you'll be fine
Gaetano Cosentino
Old 04-09-2014, 10:46 AM
You can cheat the wheels to the outside until they are pretty tight. Inside is a different story. With that being said, you can space the wheels out, you can't move them in.
Old 04-09-2014, 10:55 AM
Musclerodz's Avatar
you can run tighter with a 4 link. 1" would be about right for a leaf set up
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-09-2014, 12:16 PM
I ended up increasing my rear end width by 1/4" (1/8" on each side). This will give me around 7/8" clearance from the inside lip to the tire sidewall. That should be safe and look ok I think. So my WMS-WMS is 58 3/4" with an 18x11 rim with a 315 tire. Thanks for the input!
