Old 04-09-2014, 04:35 PM
goob8869 goob8869 is offline
Default need advice for this setup
Can you tell me if this setup will work or not. I have a 67 Camaro with a 05 Cadillac CTSv ls6 in it, but the harness and ecm are for a 99 corvette. The tach mudule, dbw pedal, and throttle bodies are from the Cadillac. I have replaced the tach module, pedal, and ecm but the car will still not crank
Old 04-09-2014, 06:23 PM
rickpaw rickpaw is offline
Meaning the starter does not engage? If so, you need to check the wiring from the ignition switch to the starter solenoid.
Also, I can be wrong (have to dig out my LS swap books), but I think the ECU (99) is not compatible to the later year engine due to different crank position sensor (24 tooth vs 58 tooth).
Tu Ho
Old 04-09-2014, 06:42 PM
The starter turns over but will not hit a lick. The fuel pump and relays keep clicking. If I unplug the tac module it will fire up but no throttle then and as soon as you plug it back up something happens
