Old 04-10-2014, 08:18 AM
69greyghost 69greyghost is offline
Default I want to run 2010 Brembo ss camaro brakes and c 6 wheels, possible?
Guys I am on a limit budget for rims so I got an idea, why not run z06 wheels on my 69 camaro. They look decent and are affordable, I know this will require some adaptors but if its safe this is an option I would like to try. My next hurdle is the e brake with the ss brembos. I have a stick so I need an e brake. What all options do I have there and will this combination work at all together?
Old 04-11-2014, 11:12 AM
Formula43 Wheel's Avatar
Formula43 Wheel Formula43 Wheel is offline
You'll need to open up the hub bore of the wheel slighty and run spacers front and rear, but it will work. Stielow used ZR1 wheels on Jackass.
