Old 04-21-2014, 10:30 PM
Ron in SoCal's Avatar
Default One man brake bleeder recommendation
I did a search in this section and didn't see anything. Looking for the best one man bleeder. I'm thinking a reverse bleeder system like Phoenix, but would love to hear opinions.
Ron in SoCal
69 Camaro in progress
Old 04-21-2014, 10:33 PM
JB400's Avatar
JB400 JB400 is offline
Been wondering this myself. People are either too busy or too lazy to pump a pedal.
Old 04-21-2014, 10:35 PM
gearheads78's Avatar
gearheads78 gearheads78 is offline
I love my Vacula I bought off the Snap On man a few years back. My wife loves it too since she no longer has to come out to the pump brakes all the time.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
Old 04-21-2014, 11:16 PM
Sieg's Avatar
Sieg Sieg is offline
I've had a Mighty Vac for years and have always had acceptable results on bikes and cars, brakes and clutches.
I'd consider this system also: http://www.summitracing.com/parts/mvp-0260/overview/
Old 04-22-2014, 05:26 AM
SSLance's Avatar
SSLance SSLance is offline
I use a Mighty Vac as well, it's super handy when flushing fluid as you can see the dirty fluid going into the capture can and can tell when you get to the new clean fluid.
I overfilled my PS pump recently and even used the Mighty Vac to suck the expensive Royal Purple fluid back out and was able to save it back into the original container for later use.
Lance
Old 04-22-2014, 05:36 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
I bought the Motive product one listed in the link but the flat aluminum plate (red) did not fit my Wilwood big bore master cylinder as indicated ..It was about a 1/16 off so it didnt seal very well and made a mess so i just bleed the ole fashion way...
I did use it on a standard master cylinder on a friends Hotrod and it worked fine. Poor fluid in, pump it up and bleed away...
More than welcome to try it if interested..
Old 04-22-2014, 05:53 AM
rickpaw rickpaw is offline
Believe it or not, I used the one from Harbor Freight
http://www.harborfreight.com/brake-f...der-92924.html
Hook it up to an air compressor, and it pulls the brake fluids through the lines using venturi effect. Did the whole system by myself, although I did get a friend to pump the pedal at the end to make sure there was no air in the system (there was none).
Tu Ho
Old 04-22-2014, 08:41 AM
renegade6 renegade6 is offline
I use a large syringe (purchase from Tractor Supply) and reverse bleed them.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 04-22-2014, 11:02 AM
I appreciate all the replies! Sounds like you guys have it figured out. I think I'd prefer to push the fluid from the Master out of the calipers. One question: I have the Wilwood resi:
http://www.wilwood.com/Images/Master...0-12696-lg.jpg
EDIT: Tech Sheet - http://www.wilwood.com/PDF/DataSheets/ds974.pdf
Any idea if the Motive or H-Freight master cylinder adapters would work?
Ron in SoCal
Old 04-22-2014, 11:24 AM
SSLance's Avatar
I would imagine that with all of these self bleeders, the success rate is going to be determined with how well the kit's adapters work with the end of the brake system you are dealing with.
The Mighty Vac comes with a large assortment of ends to put on the vacuum lines to connect it where it is needed. What I found though is the more connectors you use, the more areas there are for air to leak out which is frustrating. I would assume that the other kits that push from the MC side have similar issues but do not know that for sure.
What I found to work best is to use as few pieces as possible and be diligent that the connections are as tight as you can get them. On my rear calipers, the hose itself fits very snuggly on the bleeder screws and I route the hose so that it comes off the bleeder screw and turns up which leaves the open end of the bleeder in fluid after the air escapes. This works very well for the rears.
The hose does not fit as tightly on my front bleeders and while I can flush the old fluid out and get the caliper pretty well bled with just it, I still like to have a pedal pusher to get the last two bleeds as good as I can get them. Same theory, run the hose up from the bleeder to leave the open end immersed in fluid before closing it again.
All of this can be done under the car while it's up on the lift and all I have to watch for up above is not running the master cylinder out of brake fluid. So there is a little bit of back and forth involved, but not too much.
If someone with experience using the MC push type bleeders can chime in, how user friendly are they to use by yourself and how much of a mess is there to clean up in and around the MC once the lines are bled? How well do they adapt to different kinds of MCs as well.
Lance
