Old 04-21-2014, 11:33 PM
David Pozzi's Avatar
Default Art Morrison IRS, 73 Camaro
We recently finished the install of the new Art Morrison Enterprises IRS in Mary's 73 Camaro.
Unlike their First Gen Camaro IRS, the second gen install requires a fair amount of cutting to get it in there. Second gen's have the rear seats pushed as close as possible to the rear axle, the frame rails are vertical just ahead of the axle which poses clearance issues to the toe links. The first thing to install is the 2x4 cross-member. I chose to raise the floor to the top of this cross-member which made room for the mufflers. I added frame rail sections inside the rear seat area on top of the frame rails to beef up the strength lost by cutting away the rails in the toe link area. The new rear floor follows the reinforcements.
FEATURES
Center diff from Strange, based on Dana 60 internals. Ratios from 3:55 & lower, OR use a stock fifth gen Camaro diff.
Axles are Drive Shaft Shop, good to 1400hp.
Fifth gen outer axle carriers machined to take ZR1 HD hub/bearing units this gives you a GM bolt pattern, the Camaro has a slightly different wheel stud spacing. The Corvette hub has a larger center register than a Fifth Gen Camaro.
Stock fifth gen brakes work depending on wheel size or Willwood & Baer have 14" 6 piston brakes for it that should clear 18" wheels.
Adjustable toe-steer in turns.
INSTALLATION:
1. Mock up the IRS in the car with the frame brackets bolted on.
2. Center the wheel in the wheel arch, check for square.
3. Tack the frame brackets to the frame, (reinforcing plates should be welded on first).
4. Remove IRS then fully weld brackets.
A 2" x 4" cross-member must be installed by cutting through both frame rails, it extends pinch weld to pinch weld. There is a raised area in the floor pan that the cross-member sits half in and half into the rear seat area, so the floor pan has to be cut from the crossmember rearward. I also had to cut out the trunk floor from just above the fuel tank anchor points running 10" forward. Also the corners of the trunk drop-down needed to be cut back on an angle to allow access for welding on the frame rail reinforcement plates and cradle mounts.
New IRS
NOTE I quit Photobucket when they started charging too much so many photos are not available. I'm uploading new pics here but I don't have all of them, but Mary does.
Tie rod just clears what's left of the frame rail, only about 3/4" left, which I plated over on 3 sides with 10 ga cold rolled steel.
Note frame rail reinforcements left and right Floor is raised about 2" & slopes upward sooner. I should have cut out the tunnel straight across and made a whole new one.
I wasted a lot of time cutting out the old seat belt holes and patching them, the lower edge was not flat where it meets the new floor pans so lots of work there.
Left and right sides are the remains of the factory floor pan contour. The front cradle mounts are about an inch below the new floor, allowing installation from below by one person. The rear mounts have fairly good access by cutting off the trunk floor corners and using a Ricks gas tank with trimmed corners similar to the DSE tanks. This gives you a space to reach up and install the nuts.
welding the exhaust
Trunk filler panels
http://www.PozziRacing.com
Old 04-22-2014, 12:06 AM
Sieg's Avatar
Sieg Sieg is offline
Thanks for the insight David!
How's the weight of the system compare to the conventional axle and leafs?
Old 04-22-2014, 12:10 AM
New Baer 14" brakes & Ride Tech coil over Triple adjust shocks
Alignment
Videos: if you click the link, you may get a better quality video.
Autocross run:
https://www.youtube.com/watch?v=S-nhjVa5V4M
Popular Hotrodding video
Suspension cam:
https://www.youtube.com/watch?v=L6oz...ature=youtu.be
Old 04-22-2014, 12:12 AM
ArisESQ ArisESQ is offline
unbelievably cool. Interested what your thoughts are on how it drives compared to the solid axle. I wanna see a 2nd gen with a tiny bit of negative camber on the rear!
Old 04-22-2014, 12:15 AM
Flash68's Avatar
Flash68 Flash68 is offline
Awesome Dave! Was hoping you would post this up.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-22-2014, 12:21 AM
It's way better right out of the box! Sure footed is the best description I can give of it. The car isn't upset as easily and the street manners are outstanding!
Mary has done two local autocrosses and one in San Diego where she won the new SCCA Tour CAM (Classic American Muscle) class.
Old 04-22-2014, 06:58 AM
fleetus macmullitz's Avatar
Very helpful info David.
Feel free to post much, much more on the subject.
Old 04-22-2014, 12:40 PM
Damn True's Avatar
Damn True Damn True is offline
Awesome stuff.
Old 04-22-2014, 01:13 PM
mfain mfain is offline
Very nice. When you can share, I would be interested in your thoughts on the roll center height versus spring rates and whether you are running any toe steer with bump.
Pappy
Old 04-22-2014, 01:32 PM
I don't have the roll center height data but they say it's very stable which is the main consideration, it moves 1:1 with the body.
We are starting from scratch on spring rates and shock valving. The motion ratios are different from the stick axle we had, more like the front now. We are at 450 in spring rate which is what Morrison runs on their 69 Camaro. It works very well, I doubt we will be far from that in a year from now, but time will tell.
We started with an aggressive toe steer setting (toe out in bump) we found that to be too much and backed it down to pretty close to what Morrison runs on their 69 right now. We will experiment further.
I'm not much up to speed on the "numbers" yet, we have been so busy just getting it into the car. I'm not sure my Performance Trends software can even handle this type of suspension. I kinda doubt it.
