Old 04-22-2014, 05:43 PM
blacktop blacktop is offline
Default Holley pan 302-2
I swapping my 70 Chevelle over to a lq9 6.0 I have a 302-1 Holley pan new that was going to use on my 56 210 but sold it. What I've been reading is the inner tie rod hits the pan. Should I go with the new 302-2 pan if that does clear or is there a way to use the old pan and raise motor some without messing up drive Line angles? I have not purchased any mounts yet. Thanks for any help or suggestion. I was planning on using BRP mounts- I live 15 minutes from them so it's nice to just go there to get what I need.
Old 04-25-2014, 07:23 PM
kwhizz's Avatar
kwhizz kwhizz is offline
The 302-2 pan will give you some additional clearance as it doesn't sit as low.....but check on Holley's website as there are some other concerns with the pan
Ken
Old 04-25-2014, 07:43 PM
Ken
Concerns on the older pan?? I like the 66 you built did you use the old Holley pan? Did you raise your motor up because of tie rod issue?
Old 04-27-2014, 09:19 AM
kwhizz's Avatar
I used a -1 pan in the Chevelle......the engine is raised slightly......and there is very slight contact at full travel.....but....It's not enough for any concern......I ordered a -2 pan (they were back ordered at the time) and it came in after I already had the engine back in......after reading about it as I remember there were some windage tray issues so I was uncomfortable swapping it out in the car........so....I left the -1 in.........
Ken
Old 05-14-2014, 08:47 PM
n77nxc's Avatar
n77nxc n77nxc is offline
I just finished installing the 302-2 on my LQ9. The -2 requires a F-body Windage tray with a slight modification to a corner, in order for the oil pickup to fit properly. The modification is very simple. I wouldn't let the slight mod sway you from the 302-2.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
