Go Back   Lateral-g Forums > Technical Discussions > Man Caves
Old 04-22-2014, 06:28 PM
Default Weld's new "Shed"
Okay -- since the original post was lost in the server swap.... I'll repost this so that you guys will have reference for "before" and "after".... so here goes.
The new shop building... which was bank owned. The shop has TWO 16' high doors that are both 14' wide. Perfect for using the far right door/bay for the semi rig parking.
The main floor is 5250 square feet... so that ought to work our just fine! But it's dirty -- and lots of stuff on the walls that will be cleaned up -- and power that I can't use (480Volt 3 phase!)... So the electricians were in first - cleaning up and making safe.
This area under the upstairs will be my new "tool area".... it has heated floors!! Sweet!! It's 14' wide and 43' long -- so plenty of room for my stuff.
This building was last used to refinish doors -- so they had big sanders and a spray refinishing area ---- EVERYWHERE was sawdust and lacquer residue... so it took a bit to clean that up. They power washed EVERY SQUARE INCH -- including the ceiling and all the truss system - and then they washed the floor 4 times!
AND then this was the upstairs "office" --- what a nasty dark horrible dump that had to be to work in!! OMG just awful!
Old 04-22-2014, 06:44 PM
They gutted that horrible office ---- we added a couple windows in the walls overlooking the shop -- they'll open and the exterior window to the outside will be replaced with a window that opens as well.
The exterior wall (shop side) will get "barn wood" and a "eyebrow" shed roof over the windows made from corrugated galvanized steel.
When they put stuff back ---- I post up pictures. This IS NOT a car showroom --- it is not a "collectors" storage building.... This is a WORKING shed... the hobby to me is building and doing.... so it's not going to be done all fancy and pretty. It will be done with function over beauty... but on the other hand I'll also have some fun with portions of it.
I did acquire a couple "scale/size" appropriate signs with the new spare in mind....
Old 04-22-2014, 07:38 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Oh good, you posted this up again. We live vicariously thru you.
Someday I hope to have a big boy shed.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 04-22-2014, 07:42 PM
HAHAHAHAHAHA......
Speaking of shops - When you going to update your thread with some super fantastic "stuff"?!?!?!
Old 04-22-2014, 08:11 PM
coolwelder62's Avatar
The building looks a lot bigger in the second round of post's.
Old 04-22-2014, 08:25 PM
Am I having dejavu?
Old 04-22-2014, 08:33 PM
Jody already has me buying the vacant lot out back and remodeling the building... Just shoot me.
Old 04-22-2014, 08:34 PM
Am I having dejavu?
No ---- YOU are having one of those LSD flashbacks your high school teachers warned you about.
Old 04-22-2014, 08:38 PM
Flash68's Avatar
Flash68 Flash68 is offline
was "Bank Owned".... now just owned by another friendly bank.
Those big neon signs are kewl.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 04-22-2014, 08:41 PM
That's possible.... ha
