Old 04-29-2014, 07:29 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default T56 VSS wiring
Question for the experts...... I have a T56 Magnum in my 69 Camaro with an LS motor / PSI wiring harness. The T56 Magnum uses Ford sensors (I'm told). My question is this..... the pigtail(Ford) for the VSS and the pigtail (Ford) for the reverse light/switch are not color coded to match the LS wiring harnes.....any idea on how to connect/splice the wiring from my harness to the Ford pigtails for the VSS and reverse switch??
