Old 05-21-2006, 11:36 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Default Do sending units go bad?
I know I'm sure everything does at some point, but they're only a year old. When I got my car back from the painters, everything worked except for the water temp gauge and the electric fans - and they worked fine before hand. Strange - could the sending units go bad for just sitting around? The engine was out of the car for a while. How can I test them?
Thanks,
-Tom
camarorestoration.com
Old 06-01-2006, 09:18 PM
terryr terryr is offline
You've checked your wiring?
Did the paint shop paint over your ground wire connections. They need bare metal.
Old 06-02-2006, 01:34 AM
rockdogz's Avatar
I found out that the two sending unit wires were switched...
-Tom
