Old 05-12-2014, 08:09 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Barry Grant Fuel Cooler
Hi guys
I have got the Aeromotive EFI fuel tank which has an in tank fuel pump and the fuel system is plumbed as follows:
Feed line to passenger side fuel rail going to the second fuel rail, then returing through the Aeromotive fuel pressure regulator (mounted on the firewall) back to the the tank similar to option no 2 in the photo below
I was about a bit concerned about hot fuel and vapor lock issues so I bought a brand new Barry Grant fuel cooler with 8AN fittings as shown below
Once I received the fuel cooler, I noticed as per the instruction is this fuel cooler works well with flow-through-style fuel pumps.
I was planning to install the cooler in the return line to cool down the fuel going back to the tank.
The Barry Grant cooler has a check valve with defined inlet and outlet ports
My question is can I use this fuel cooler with in tank fuel pump or it works only with flow through stye fuel pump
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 05-13-2014, 10:04 AM
72Z/28's Avatar
Anyone??plz
72 Camaro RS:SOLD
68 Camaro:
