Old 05-13-2014, 02:21 AM
6camaro9's Avatar
6camaro9 6camaro9 is offline
Default DSE pump and 600 box.
I'm running a DSE ps pump and there 600 steering box along with there hose kit and the problem that i am running into is that i can not get the return fitting at the pump to seal. I put the 1/4NPT to 6AN fitting in the pump tank this winter and it is working great no leaks but I can not get the hose fitting to work. I was wondering if anybody might be able to tell me what fitting they are using. The 6AN fitting i have now seems like it might be a little to small for the hose and before i order another fitting i wanted to see what you guys are running. I've called DSE but they have not really been able to help me.
Richard
Old 05-20-2014, 08:51 AM
62wagon's Avatar
62wagon 62wagon is offline
Richard, You may have this complete but if not, the return hose in the DSE kit is actually slightly larger than a -6 hose. The pressure hose is a true -6 size. To use an off the shelf hose kit, you can't put a -6 hose end on the return side. They have a bent 90-degree tube that will allow you to use your current hose kit and the adapter in the reservoir. Here is a link to the fitting: http://www.detroitspeed.com/Steering...turn-hose.html Hope this helps. Mark
Old 05-20-2014, 02:11 PM
6camaro9's Avatar
Thanks for the information, as many times as i have been on there web page I had never seen that fitting. I have about went crazy trying to find something that would fit. I had evan talked to DSE and they had not said a thing about it. I found a fitting made by fragola and it is working so far and apears not to be leaking. If it does start back though i will order the tube. Thanks alot for the help.
