Old 05-14-2014, 10:31 PM
Bootleg1 Bootleg1 is offline
Default T56 Magnum set up housing
This should probably have been part of our build thread on the 66 Cyclone, but I figured it was more appropriate in the trans section.
We will be getting our rearend housing back from Currie tomorrow and should have it hung in the car early next week. We need to build a sub frame to connect the TCI front and rear suspension, as they did not have a system long enough for the Cyclone. We have a mock up engine block but would like to know if anyone has a T56 Magnum case and tail shaft housing we could use to build the trans cross member into the subframe. Damaged is fine as long as mounting points are in the correct spot. We will purchase a bell housing for the Windsor block to use for the mock up. We could send a deposit for the housing and would gladly offer up the Derale cooler of your choice for letting us borrow it.
We would like to have it for 30 days to get the firewall cut out and subframe built. If anyone could help us out we would greatly appreciate it.
Ted
Derale Performance Products
Old 05-15-2014, 07:55 AM
forcepower forcepower is offline
you might want to contact Liberty gear or D&D performance, both in Michigan to see if they have any cracked or damaged parts. I know liberty gear has a scrap bin of numerous parts. I have a t56 main case but I think its different from the magnum case. Good luck with the hunt
Old 05-15-2014, 08:18 AM
I will give them a call this morning.
Thank You
