Old 05-23-2014, 08:11 PM
kevin_l's Avatar
kevin_l kevin_l is offline
Default 315's too wide for a 10" wheel?
After the mini tub on my 66 chevy II, dse says I can fit 11" wide wheels, but I am really having trouble finding a 11" wheel in my budget. Most manufacturers go 9,10,12. I still want to run 315's in the rear so would you think it's ok on a 10" wheel? If you guys have any info or pictures of your tires mounted I'd really appreciate it. Thank you
Old 05-23-2014, 08:44 PM
CURVES's Avatar
CURVES CURVES is offline
Yeah Kevin, a 315 is too wide for a 10" wheel.
The range is generally 10.5 to 11.5.
SCOTT
71 Camaro project. "Mulletmobile"
66 el camino "Pye Wagon"
69 Camaro. sold
Old 05-23-2014, 10:19 PM
Flash68's Avatar
Flash68 Flash68 is offline
The range actually goes to 12 at least.
Nitto approves up to a 12.5 on a 315.
https://www.nittotire.com/Tire/Competition/nt01#size
But yeah I would not do a 10" wheel on a 315. No bueno.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 05-23-2014, 10:31 PM
Track Junky's Avatar
Depends on tire manufacturer. Tire manufacturer goes by measured rim width which could be up to 1 1/4" wider than advertised rim width. So your 10" wheel could actually measure 11 1/4" wide.
Gaetano Cosentino
Old 05-23-2014, 11:16 PM
Vince@Meanstreets's Avatar
no no no they go by bead surface which is the standard measure when ordering wheels.
lets not through another wrench in the thought process please.
I put 315's on a 10.5 and it looked bulgy.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 05-23-2014, 11:20 PM
if you on a budget there is always 17 x 11 american racing TTII's I thought I heard they have a sale going on..... $199 each.
Dealer for
NEVER FORGET -11
Pretty much what I meant to say. Inside to inside of bead surface but thanks Vince. Either way the difference could be up to 1 1/4"
Gaetano Cosentino
Old 05-24-2014, 02:35 AM
kevin_l's Avatar
Ok thanks guys, I like ttII's but they won't clear c6 brakes
Old 05-24-2014, 09:45 AM
This isn't a "looks" issue.... this is a what is safe and what something IS or IS NOT made for.
Go by the tire manufacturers recommended wheel size for YOUR tire choice.
Old 05-24-2014, 09:51 AM
It's also a performance problem. Putting more rubber on a wheel that's to small will lead to less performance than a properly sized tire.
