Old 06-30-2014, 08:35 AM
SkeWest SkeWest is offline
Default Headers that fit with ridetech tru turn on 1969 Camaro
Hi. I've got a 69 Camaro with a sbc and I'm having issues finding headers that will fit with the tru turn setup. I've done some searching and found some that say the Dynatech #740-21310 will clear but the thread was a couple of years old so I thought I'd see if anyone had any additional info. I called Ridetech and they told me that people have had luck with Dynatech and Summit, but they couldn't give me any specific model numbers.
My setup is sbc with straight plugs, ridetech tubular a arms, muscle bar, and coil overs. M22, vintage air front runner, compact starter, and stock steering box.
Thanks for any help
Old 06-30-2014, 10:05 AM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
I have dynatech headers and slide in place without any issues with stock steering box. Just have to get the car up high enough to clear the ground cause they have t ogo in at an angle fromt the bottom......My plugs are angled though, so not sure about straight plug heads.
Old 06-30-2014, 11:18 AM
Thanks. What model of dynatechs are you using?
Old 06-30-2014, 11:42 AM
RBuhr69's Avatar
these are the ones I have..
1 5/8 - 1 3/4
http://www.summitracing.com/parts/DTC-740-23210/
Others have said the yused the bigger tube one..
1 3/4-1 7/8 stepped headers. Part # 740-21310
Old 06-30-2014, 02:13 PM
Thanks a lot!
Old 06-30-2014, 05:25 PM
RBuhr69's Avatar
Here is a photo of them installed and the clearance by the pitman arm and drag link..This is the area to be concerned with.
Old 07-01-2014, 09:22 AM
Perfect! Just ordered mine. Thanks again.
