Old 06-30-2014, 06:02 PM
wrighton wrighton is offline
Default what rack and pinion for Scott Mock sub frame
I have lost my notes and have been thinking about putting my sub frame together to make the car a roller. It's a scott mock sub and I just want to pick up a rebuild rack and pinion at the local parts store. I could not remember if it was late 90s thunderbird? mustang?
Old 06-30-2014, 06:33 PM
Jr's Avatar
Jr Jr is offline
I believe it's a mustang.
Call Scott to confirm.
Old 06-30-2014, 10:48 PM
Build-It-Break-it's Avatar
Its a 89 up mustang rack. I have the same subframe.
Old 07-01-2014, 05:39 PM
Thanks for the reply
Old 07-11-2014, 02:22 PM
coolwelder62's Avatar
Any 1979-1993 Mustang Fox bodied rack & pinion will work. They come in a 15:1 & 20:1 ratio's. If you get a rebuilt unit from the auto part store ask for a set of 2pc. bushing then use some .750 od x.085 wall 4130 tubing for inserts.The GT mustang's came w/the faster ratio's,thay all a have 3/4x36 spline end.You also want to use the tie rod ends from the same mustang,and a 9/16x18 jam nuts.Some rebuilders send them with jam nuts some don't.
