Old 07-03-2014, 04:33 PM
Snipe00 Snipe00 is offline
Default Ordering parts, are they right?
I am removing the auto from my 69 camaro and will be putting a rebuild Muncie in its place and I just had a question about what clutch and flywheel i should be using. Currently I have a 383, has a 10066036 casting so it has the 2 piece seal. So what I am looking at is the McLeod Clutch Kit (75224) and a ACT flywheel (600470). Then for bell housing i found this 621. So before i order these like i said i wanted to make sure it would work, first time doing this so i want to try and minimize my possible future problems, or if another product would be recommended. Also does anyone had any good 4th of july sales seeing as i still have to order the pedals and all that good stuff as well.
Thanks in advance for the help and have a safe Holiday.
Old 07-04-2014, 08:12 AM
Your motor is INTERNALLY BALANCED..... So that's what you need to be sure of as far as rotating parts -- that they work with INTERNALLY BALANCED engines.
Single rear seal engine SBC's are EXTERNALLY balanced.
