Old 07-05-2014, 04:46 PM
ProTouring442's Avatar
Default Bonding Fiberglass to Metal
Is there a way to bond fiberglass to metal and hide the blend, in a way that lasts? I figure the secret is in having a large transfer area, but I don't know if that really works.
The idea is to bond fiberglass widened rear quarters on a 240Z. The quarters look like this:
Thanks!
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 07-05-2014, 05:57 PM
66fury's Avatar
66fury 66fury is offline
3m has a series of bonding adhesives that are great
mark
Old 07-05-2014, 07:21 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
For my fiberglass work I use West Systems products. I use their six10 epoxy bond. 24 hour cure time, after than it can be sanded down and you can apply filler over it, or prime etc.
Unbelievable products.
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 07-06-2014, 05:42 AM
dhutton dhutton is offline
I have had good luck with 3M 8115 panel adhesive.
Don
Old 07-06-2014, 09:03 PM
broken1234 broken1234 is offline
Is the West six10 recommended for metal?
Old 07-08-2014, 04:58 AM
Boss 5.0's Avatar
If you were to read the packaging it is recommended for most everything. I use it all the time, it is incredible stuff.
On my fiberglass hood, there was too wide of a gap to the fenders. I couldn't move the fenders in any more. So I made some aluminum backers on the bottom of my hood and ran a heavy bead along the edge of the hood. 24 hours later I peeled the backer off. I was then able to block sand the epoxy to a perfect gap with the fender. And, if I were to hit it with a hammer it will not chip off, it has become part of the hood. This stuff rocks.
I have used it on metal without fail.
http://www.westsystem.com/ss/new-six10-epoxy-adhesive/
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
