Old 07-11-2014, 12:55 PM
BMR Sales's Avatar
Default BMR Suspension Releases New Products - A-Body Control Arms (TCA034)
1964-1972 A-Body Tubular Lower Control Arm
TCA034 - $159.95
Reduce wheel hop, launch harder, and add cornering consistency to your 1964-1972 A-body with Tubular Lower Control Arms from BMR Suspension. These round-tube control arms are manufactured from 1.50-inch DOM tubing, which dramatically increases strength over the stock stamped-steel arms, while remaining an economical option for improved handling. The BMR Tubular Lower Control Arms (PN TCA034) use 2.0-inch greasable, high-durometer, spiral-fluted, polyurethane bushings, leaving you with a solid, more responsive feel over the factory rubber bushings. Combined with reduced control arm flex, the handling of your A-body will be much more predictable and consistent on the street and on the track. The BMR Tubular Lower Control Arms also retain the factory sway bar mounts. Installation time is 2-3 hours. Available in black hammertone or red powerdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
