Old 07-13-2014, 08:44 PM
surewhynot surewhynot is offline
Default coil over angles
I recently installed the lt1 style rear brakes on my 1985 cutlass. II had to relocate the shocks, therefore i made my own bracket. The bracket itself is stable, but i do not like the look of it, and i just do not trust it (ocd/ overthinking in my head.) My question is, if i convert to coilovers, i was thinking of welding in a frame tie and mounting the upper mount to that, and making a new lower mount attached to the rear, what is the optimal angle to moun the coilover assembly to optimize handling? Thanks in advance
Old 07-13-2014, 11:09 PM
Vince@Meanstreets's Avatar
Ideally, you want the spring inline with the applied force. Typical road race setup has 5-10* but most often packaging can dictate positions.
Body roll makes a difference on what is actually inline with the applied force. You also want the lower mount pointing at the center of tire contact patch to keep leverage effects at a minimum. 5 degrees or so would be about right.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-15-2014, 11:09 AM
Rod P's Avatar
Rod P Rod P is offline
yeesh! someone has their smarty pants on
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 07-16-2014, 10:07 AM
. Hey, just put a moderate order in... Please don't fart in my shipment. : )
Dealer for
NEVER FORGET -11
Old 07-16-2014, 12:50 PM
Ron Sutton's Avatar
LOL
Ron Sutton Race Technology
