Old 07-14-2014, 01:10 PM
DBasher's Avatar
DBasher DBasher is offline
Default Wheel spacers
Good ones, bad ones, how much is too much...
It looks like I need 3/4" per side on the back of the wife's mustang to make everything happy. Never used them before and I need a bit of schooling.
Dan
Old 07-14-2014, 01:48 PM
Vince@Meanstreets's Avatar
I have used up to 1" but with no issues but over that I would recommend a studded wheel adapter.
http://www.summitracing.com/parts/bae-2000012/overview/ spacer
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 07-14-2014, 10:07 PM
DBasher's Avatar
Thanks Vince, I'll look at Jegs again and get something coming.
Dan
Old 07-15-2014, 06:27 AM
barrrf's Avatar
barrrf barrrf is offline
You'll need longer studs with 3/4" spacer. Or extended shank lug nuts IF your wheel will accept them.
I have 2 thin spacers in the back on my car. I also have 1" spacers on my truck. No Problems.
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 07-15-2014, 10:30 AM
DBasher's Avatar
I'll be running 3" studs so should be ok there.
I was wondering about stacking shims, if 3/4" wasn't enough could I run another 1/8". I actually found a guy in the neighborhood that makes spacers and will do what ever size is needed, bonus!
Dan
Old 07-16-2014, 06:42 AM
barrrf's Avatar
No problem with stacking. You lose nothing in clamping force no matter how many shims are there.
