Old 07-19-2014, 05:53 PM
malo69 malo69 is offline
Default neutral safety switch
what neutral safety switch do I need for a ls2 with 6 speed in a 69 Camaro where can I get one?
Old 07-19-2014, 11:31 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Switch goes on the clutch pedal. It is just like a brake switch for a brake pedal. The question you need to answer is what kind if pedals are you using?
Are you using stock pedals? Are you using a late model wiring harness or a stock 1969 harness? Either way you should be able to get a switch from a Camaro restoration parts house or if you plan on using a late model switch check a junk yard or eBay.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 07-20-2014, 12:32 PM
ok thank you im using stock pedals and a new American auto wiring kit
Old 07-20-2014, 09:09 PM
jwcarguy jwcarguy is offline
Banned
I run into through the starter circuit (w/relay added) also using a AAW Update wiring harnesses
clutch pedal activated switch (clutch has to be depressed for car to crank over / start)
Hope this helps
Jeff
Old 07-21-2014, 09:54 AM
Musclerodz's Avatar
brake pedal switch (umless you get creative and use a relay) can't handle the amps the neutral saftery switch will. Use factory nss, I get them from Firewheel Classics, but any major vendor like Classic Industries or Year One should have them
Mike Redpath
Musclerodz & Customz
facebook page
