Old 07-19-2014, 06:14 PM
malo69 malo69 is offline
Default wiring
Ok im about to start the wiring on my 69 Camaro I bought the American auto kit for the car it has a ls2 with a 6 speed. the engine harness came with the plug for the alternator but the car harness also has a wire for the alternator what do I need to do ??
Old 07-20-2014, 06:38 AM
dhutton dhutton is offline
I used the one in the engine harness.
Don
Old 07-20-2014, 09:03 AM
Musclerodz's Avatar
use the one on the engine harness
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-20-2014, 12:22 PM
thank you guys so remove the one on the American auto wire harness ?
Old 07-20-2014, 09:11 PM
jwcarguy jwcarguy is offline
Banned
X3 on engine harness plug
Double check that the "alternator" wire in your AAW kit is a reference wiring for a voltmeter gauge??
I don't have a copy of the AAW wiring diagram handy to verify that and last car was about a year ago
Jeff
Old 07-21-2014, 06:07 AM
thanks JW ill look into it
Old 07-21-2014, 09:07 AM
130fe 130fe is offline
Thumbs up
I concur with the others, just use the ls harness alt connection. Here is the AAW eng wiring diagram- http://www.americanautowire.com/PDFL...20IN%206.0.pdf
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-21-2014, 09:51 AM
Musclerodz's Avatar
The one in the AAW kit simply runs from the alt to the starter which connects to the bat. That is also where the fuse panel picks up its power. You do away with that one so the ecm can control the alt.
Mike Redpath
facebook page
Old 07-21-2014, 04:00 PM
Thank you guys for all your help I got it done !!!!
