Old 07-21-2014, 05:08 PM
fillpot fillpot is offline
Default Holley accessory brackets
Guy's been thinking about swapping my truck accessories out for these but had a question,can I use my powersteering pump, alternator,etc with this, I know I would change out the p/s resivor because that is one of my problems being real close to a control arm bolt, any thing else needed, this is a trailblazer ls2 in a 69 Camaro btw. THANKS!
Old 07-23-2014, 11:49 AM
Efi69Cam Efi69Cam is offline
Originally Posted by fillpot View Post
Guy's been thinking about swapping my truck accessories out for these but had a question,can I use my powersteering pump, alternator,etc with this, I no I would change out the p/s resivor because that is one of my problems being real close to a control arm bolt, any thing else needed, this is a trailblazer ls2 in a 69 Camaro btw. THANKS!
Everything but the PS pump will work. I have their bracket for the AC compressor and it looks like a nicer casting than the GM Alt/PS bracket on the other side.
Old 07-23-2014, 09:36 PM
What pump corvette style? THANKS!
Old 07-24-2014, 03:28 PM
69lsvert 69lsvert is offline
I just ordered the ac and alt bracket from Holley to move them to the top. I have the ls6 so maybe a lot different from yours. I'll let you know how they work out.
Old 07-24-2014, 03:38 PM
Thanks!
Old 07-25-2014, 08:08 PM
Uses the C5 Corvette PS pump and reservoir.
Old 08-05-2014, 05:01 AM
sebtarta sebtarta is offline
This is the Holley Accessory Bracket
This is the kit
https://holley.com/products/accessor...y/parts/20-132
I bought them separately on Amazon as it was much much cheaper. Use this link for all the part #s needed for assembly.
https://holley.com/document/199r10613rev7.pdf
The only concern I have is that if you have any UCA it might be to close once you add the shims for alignment using the recommended 6" PSP pulley .
--edit--
Forgot to add, 72 Nova
Old 08-05-2014, 09:36 AM
67Rally's Avatar
67Rally 67Rally is offline
You should be fine. I don't think you could shim the UCA out far enough for it to hit. And if the engine is going to move under acceleraion, it's going to move towards the passenger side.
Nice looking setup by the way!
Old 08-05-2014, 11:57 AM
Man that does look great, I haven't had a chance to fool with the accessories lately been chasing a wiring issue, with this bracket I'll use the corvette pump and reservoir and that should be it? Im at work now I'll look at the fitment guide tonight. THANKS!
Old 08-06-2014, 07:04 AM
Thanks, most of the build is on ls1tech as you know.
Yes use the pump and reservoir as mentioned before.
