Closed Thread
Old 08-06-2014, 07:44 PM
garickman garickman is offline
Default Wegner Built LS7 Dry Sump Engine
Item Location (City/State):Tracy, California
Price:$27,500.00
Description:
Well, I was hoping that it didn’t get to this point but some personal and family issues have come up and I will be selling this engine.
I’m not going into great detail because if you are a serious potential buyer, I am sure you will want to contact me by phone or in person.
I can tell you this engine was built with extremely high end parts and no expense was spared. It was built by Wegner Motorsports who is one of the best LS engine builders in the country. The engine has had the initial break in and was dyno tested at Wegner Motorsports producing 710HP and 653 pounds of torque. Casey Wegner said the throttle response to the Harrop ITB’s was insane. It was also built with some street manners in mind and should get 17-20 MPG.
Here is a link to the video of the dyno test at Wegner Motorsports.
https://www.youtube.com/watch?v=JWnl9Cc4tqc
Here is a list of all the parts used on this engine build at a cost of more than $33,000.00. I will also provide the buyer with an invoice of almost $4,500 for the work and dyno test performed at Wegner Motorsports. The total cost of this engine is upwards of $37,500.00
ENGINE
RHS LS ALUMINUM RACE BLOCK $4,937.00
9.750” TALL DECK, 4.165” BORE
PART #54900
www.racingheadservice.com
RHS PRO ELITE LS7 CYLINDER HEADS $3,680.00
PART #54501-06STI
RHS RACE BLOCK INTAKE SPACER KIT $254.00
PART #549109
RHS RACE BLOCK PISTON OILER KIT $734.00
PART #549120
RHS TALL DECK RACE BLOCK TIMING COVER $250.00
PART #5496
RHS HEAD GASKET SET $233.00
PART #549402-SET
www.rasingheadservice.com
COMP CAMS SHAFT ROCKER SYSTEM $1,693.00
PART #1525
www.compcams.com
COMP CAMS SHORT TRAVEL RACE LIFTERS $548.00
PART #15956-16
www.compcams.com
COMP CAMS ADJUSTABLE TIMING SET $267.00
PART #3173KT
www.compperformancegroupstores.com
COMP CAMS CUSTOM GRIND CAM SHAFT $397.00
PART #54-000-11
www.compcams.com
WEGNER MOTORSPORTS LS FRONT DRIVE, DIAMOND CUT $2,725.00
FINISH, UPGRADED 225 AMP ALTERNATOR
PART #WAK033
www.wegnerautomotive.com
CALLIES DRAGON SLAYER CRANKSHAFT WITH 24X BILLET $1,670.00
ONE PIECE RELUCTOR
PART #APU31V-DS
www.callies.com
CALLIES ULTRA I BEAM CONNECTING RODS $1,550.00
PART #U17171
www.callies.com
HARROP HURRICANE ITB INTAKE MANIFOLD $4,950.00
PART #LS7 HURRICANE
www.harrop.com.au
HARROP HURRICANE TRUMPET FLANGE $55.00
PART #99-FLG11432
www.harrop.com.au
ARP HEAD STUD KIT FOR LSX 6 BOLT HEADS $520.00
PART #234-4319
www.arp-bolts.com
ARP MOTOR MOUNT BOLTS, 12 POINT STAINLESS STEEL $23.00
PART #434-3101
www.arp-bolts.com
ARP TIMING COVER BOLT KIT, 12 POINT STAINLESS STEEL $29.00
PART #434-1502
www.arp-bolts.com
ARP INTAKE MANIFOLD BOLT KIT, 12 POINT STAINLESS STEEL $36.00
PART #434-2101
www.arp-bolts.com
ARP HEADER BOLTS, 12 POINT STAINLESS STEEL $47.00
PART #434-1202
www.arp-bolts.com
ARP REAR MOTOR COVER BOLTS, 12 POINT STAINLESS $30.00
PART #434-1504
www.arp-bolts.com
ARP OIL PAN BOLTS $57.00
PART #434-6902
www.arp-bolts.com
ARP TIMING COVER BOLTS $30.00
PART #434-1502
www.arp-bolts.com
ARP VALVE COVER BOLTS $51.00
PART #400-7530
www.arp-bolts.com
ARP WATER PUMP BOLTS $37.00
PART #434-3202
www.arp-bolts.com
ARP HARMONIC BALANCER BOLT KIT $32.00
PART #234-2503
www.arp-bolts.com
ARP VALLEY COVER BOLTS $35.00
PART #434-8002
www.arp-bolts.com
ARP THERMOSTAT HOUSING BOLTS $7.00
PART #434-7401
www.arp-bolts.com
ARP CAM RETAINER BOLT KIT $8.00
PART #134-1002
www.arp-bolts.com
ARP CAM SPROCKET BOLT KIT $7.00
PART #134-1003
VINTAGE AIR STAINLESS HEATER HOSE ADAPTER $22.00
3/8” NPT TO #10 O-RING
PART #36032-MPA
www.vintageair.com
1/2” NPT TO # 10 O-RING
PART #36033-MPA
www.vintageair.com
PETERSON FLUID SYSTEMS LS7 DRY SUMP OIL TANK $672.00
PART #08-0025-ATS
www.petersonfluidsys.com
PETERSON FLUID SYSTEMS REMOTE OIL FILTER/PRIMER $412.00
PART #09-1501
PETERSON FLUID SYSTEMS MOUNTING BRACKET $52.00
PART #09-1594
PETERSON FLUID SYSTEMS LS7 DRY SUMP BREATHER CAN $264.00
PART #08-400-ATS
LS STEAM LINE KIT $140.00
PART #78-10000
www.crracing.com
GENERAL MOTORS CRANKSHAFT SENSOR 24X $70.00
PART #12560228
PROTHANE MOTOR MOUNTS $59.00
PART #7-504-BL
www.prothane.com
AN PORT ADAPTER -12AN O-RING TO -10AN STRAIGHT $20.00
PART #AT985011ERL
www.earls.co.uk
GRANATELLI MOTORSPORTS LS7 80K COIL KIT $645.00
PART #28-0513CP
www.granatellimotorsports.com
TCI PERMANENT MAGNET RACING STARTER $282.00
PART #351110
www.tciauto.com
DEATSCHWERKS BOSCH EV14 60mm FUEL INJECTORS $489.00
PART #18U-00-0060-8
www.deatschwerks.com
DAILEY ENGINEERING 3 STAGE OIL PUMP $1,315.00
PART #04-99-2371-2
www.daileyengineering.com
DAILEY ENGINEERING LS 3 STAGE OIL PAN $1,500.00
PART #20-02-0666-ASSY
DAILEY ENGINEERING PULLEY ASSEMBLY $100.00
PART #HP-31-115-.500
DAILEY ENGINEERING BELT $30.00
PART #624-8MM-20
DIAMOND RACING CUSTOM PISTONS $1,390.00
www.diamondracing.net
KATECH CARBON FIBER VALVE COVERS $750.00
PART #KAT-A5032
www.katechengines.com
GM LS7 REAR MAIN SEAL $20.00
PART #89018162
COMETIC LS OIL PAN GASKET $55.00
PART #202-C5173
www.cometic.com
TOTAL PARTS $33,201.00
TOTAL LABOR $4,200.00
TOTAL BUILD $37,401.00
Greg
Old 08-06-2014, 08:35 PM
Che70velle's Avatar
This is a DEAL fellers!
Marcus...it's even your favorite color!
Greg, I hate you have to sell, but it sure is pretty.
Thanks Dad!!
Old 08-06-2014, 09:12 PM
carbuff's Avatar
carbuff carbuff is offline
That sure would make a nice drop-in replacement for TOW. Best of luck with the sale!
Old 08-06-2014, 11:02 PM
Vince@Meanstreets's Avatar
its the right color too
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-06-2014, 11:31 PM
Flash68's Avatar
Flash68 Flash68 is offline
I see the bore, but I don't see the stroke... So what is the CID?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 08-07-2014, 07:04 AM
It's a 4.125 stroke making the engine 450 cubic inches. With the tall deck, I could have went with a longer stroke making the engine 502 cubic inches, but after lengthy talks with both Thomson Automotive and Wegner Motorsports it was decided to go with the 4.125 stroke. The reasoning for this was to make the engine more street friendly with better fuel mileage and a much longer life.
Here is what Ron Sutton said about it,
"These numbers are nice ...
710 HP @ 6400
651.5 FT LBS @ 5100
But the thing that is bad ass is the flat torque curve and hp like a rheostat. This thing will be great to drive. That cam you posted is the key to this wide power band."
Greg
Old 08-07-2014, 03:00 PM
71RS/SS396's Avatar
That's a smokin deal, I just built a nearly identical engine and have more into mine than the asking price for this one. GLWS!
Old 08-08-2014, 01:31 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
Yep, y'all know I started drooling when I saw that blue. Looks to be my exact paint code too.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-08-2014, 02:17 PM
Rick D's Avatar
Rick D Rick D is offline
Sooooo Marcus, why not just buy this one and be done??
Rick
Old 08-08-2014, 03:23 PM
Che70velle's Avatar
Yeah! I can already see this with that gold plated supercharger sitting on it that your hiding...
All kidding aside Marcus, this is a DEAL!!!!!!
Thanks Dad!!
Closed Thread
