Old 08-31-2014, 02:05 PM
ma73z's Avatar
ma73z ma73z is offline
Default Rust question
So I've been a slacker and let an area go untreated or primed for to long and need to quiz you guys on the best way to treat the area before I shoot epoxy on it.
This is what it looks like after 80 grit on da.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 08-31-2014, 11:24 PM
Vince@Meanstreets's Avatar
That is light but its deep. Sanding it may push it deeper.
I would use a rust dissolver/remover such as http://www.harborfreight.com/http-ww...6431-html.html
then wipe down with some metal prep.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 09-01-2014, 05:01 AM
Rick D's Avatar
Rick D Rick D is offline
Not sure on this one Vince?? I'm not a big fan metal prep either
I would take a small hand sandblaster and just blast it clean. That's what I do for areas like that.
Those converters can leave behind residue that can work its way back up after paint. Ask me how I know
Oh I've never done it but have seen it a few times at resto shops with issues.
Rick
Old 09-01-2014, 05:05 AM
Rick D's Avatar
I bought this little guy a year ago and it work well for small spots and keeps them mess to a minimum.
http://t.harborfreight.com/abrasive-...bag-60308.html
Rick
Old 09-01-2014, 06:04 AM
ma73z's Avatar
Thanks fellas, I'll try the spot blaster first and see how it does and go from there.
Old 09-01-2014, 10:43 AM
Not sure if you had acess to a blaster. That would be the best way but it takes a while.
Rick, those are rust removers and not to be confused with converters or sealers. I left a rusty bracket in this stuff over night and it came out looking like an NOS piece after wards.
There's a few videos of the stuff being used. One where a guy it treating a hood section. He made a dam with tape and plastic and let it soak. A perfect technieque for a roof panel.
A vid of it used on a coil spring.
Dealer for
NEVER FORGET -11
