Old 09-18-2014, 09:16 PM
MadMaxx MadMaxx is offline
Default Needing some expert advice...
So I'm about to pull the trigger on a LS3 and finish my 69 Camaro that I started 8 years ago... Once I decide which LS3 and where I'm buying it, I am wondering if there is a kit I can buy to install my brand new ( 8 yrs old ) TKO-600 tremec transmission behind the LS3. I'm wondering what bell housing, hydraulic clutch ect is a trouble free kit / route to go. The engine is either gonna be a LS3 GM crate 525hp or a Texas Speed LS3 630 hp. This is going to be a cruiser / once in a great while a few trips down the drag strip (maybe). I was told the factory flywheel will be fine, but looking for some help.
Thanks!
Old 09-19-2014, 11:51 AM
Vince@Meanstreets's Avatar
Im far from expert but we used a stock 621 bell housing, truck flywheel (NFW-1050) and standard clutch (RAM-88764) with 26 splines with a TKO600 onto an LS3.
For hydraulics we used an actuator set up from Speedway Motors and our master cylinder plate set up. http://www.shop.meanstreetsperforman...-BCBPKIT69.htm
For race you might want to go with a SFI bell and centerforce clutch.
flywheel info 2001-2005 Silverado 1500 BaseV8 - 4.8L vin V 294ci - MFI GAS OHV
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 09-19-2014, 12:08 PM
Thanks Vince! I appreciate your input.
Old 10-05-2014, 10:15 PM
Please post some pictures when you get the motor. I'll be watching for post on the install.
