Old 09-19-2014, 05:24 PM
vstol vstol is offline
Default LS external fuel pump
I have a LS 427 fuel injection motor 618hp and am looking for a good inline fuel pump and set up. Car will see the road race track once a year and a few auto crosses but mainly a street car. Looking for your feed back. Thanks
https://lateral-g.net/forums/showthread.php4?t=44704
Old 09-19-2014, 06:51 PM
ADiCarlo ADiCarlo is offline
I see that you have an fuel safe fuel cell which is the same set up I have.
I've been considering running an in tank pump with a a surge box made by ATL that can fit inside a fuel cell.
http://www.atlinc.com/pdfs/Racing/AT...log-Page20.pdf
Is there a specific reason you want to run external?
Old 09-20-2014, 05:09 AM
I'm not sure I can run a pump inside with the current set up of the fuel cell. I will need to call fuel safe to find out.
Old 09-20-2014, 06:13 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
Im running an external walbro 255, you have double my HP so you might need two pumps to keep up and possibly put some heat syncs on the pump since they are external and will be working hard.
Alabama
1969 Camaro
1978 Camaro
Old 09-21-2014, 03:39 PM
Thanks Mike I think your right, anyone else?
Old 09-27-2014, 06:47 AM
The Bosch 044 inline pump will go 685BHP where the Walbro 255 is 390. I have read nothing but great things about the Bosch 044, looks like that is the high HP tuners preference.
Old 09-29-2014, 04:01 AM
IndyNova's Avatar
IndyNova IndyNova is offline
I've got an 044 pump I'll be running. Should fire it up in a couple weeks
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 09-29-2014, 06:41 AM
Rod P's Avatar
Rod P Rod P is offline
I have used the Holley 12-700 pump system for almost 2 years now the key to a GREAT system is the return line, sure you can run a dead head system but a fuel system with a return line runs cooler, smoother, draws less amps, and is quieter. With the 12-700 you decide fuel injection or carb with the regulator, really easy, Im switching to an intank setup with baffles for large tracks
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 09-29-2014, 05:53 PM
great thanks and I do plan on using a return line
Old 10-08-2014, 06:15 PM
surewhynot surewhynot is offline
i looked into the bosch 044 and bosch says install should be in conjunction with a second in-tank pump, my question is can the 044 be used by itself?
