View Poll Results: On a budget, would you?
Stay with Front Suspension Geometry Pro 0 0%
Upgrade to Susprog for front and rear 1 25.00%
Upgrade to Performance Trends front only 1 25.00%
Get the full Performance Trends. 2 50.00%
Voters: 4. You may not vote on this poll
Old 09-23-2014, 03:45 PM
zo6s10 zo6s10 is offline
Default Suspension software.
So I bought Front Suspension Geometry Pro a few years back. Not a bad program for the money and I like that you can add shims. I have yet to hear of someone using this program however
http://www.auto-ware.com/software/asgp/asgp.htm
Next one I was looking at was Susprog. Does front and rear for a decent price but again, have yet to see anyone use it.
http://www.susprog.com/index.htm
Then of course there is the one everyone seems to use, Performance Trends. I'm thinking there must be a reason most of the pros use it. Only problem is the full vehical version is out of the budget right now. http://performancetrends.com/SuspAnzr.htm
Should I just wait another week or so and get Performance trends full or stick with what I have?
-Eric
Old 09-26-2014, 10:52 PM
funcars funcars is offline
I've been using susprog for about 15 years. It works well and gives you a lot of info to work with.
Good luck with whatever you choose
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 09-27-2014, 06:52 AM
Thanks for the input.
I'm at the point where I think I'll just buy the performance trends full software so if I need some help I can send a file to someone for help. I do like the "shim" input but dont know if it is a shim or changes pick up points in fgsp. Don't know if the other programs have that or not.
-Eric
Old 09-29-2014, 09:57 PM
David Pozzi's Avatar
I'd get the Performance Trends software.
You can upgrade to the full version later, I think you just pay the difference in price.
http://www.PozziRacing.com
Old 10-03-2014, 05:45 PM
You can upgrade to the full version later.
Thanks Mr. Pozzi, your input means a lot to me. You and Mary are my Idols.
-Eric
Old 10-09-2014, 09:58 AM
Ron Sutton's Avatar
I personally use, recommend & sell the Performance Trends software products for a few key reasons. Besides being accurate, they're easier to use than most others, have good visuals, great graphs & you can buy the level you need without having to buy a full blown race car designing version.
The three common versions I recommend are:
1. PT's basic front suspension software, called "Roll Center Calculator"
I recommend this version for car guys working out their front roll center, camber gain, dive evaluations, etc. It's only $79. Go HERE.
2. A better route is getting their "Roll Center Calculator PLUS"
For $129 ... it also includes rear suspension & overall handling calculations, which I think is important. The FLLD calculation in the "Plus" is worth the price of the software all by itself, because you can work out combinations of roll center, spring rates & sway bar rates and KNOW how balanced the car will be. This allows you to work out your spring & sway bar rates ... front & rear ... for a neutral handling balanced car. Go HERE.
Both of these software versions above are pretty easy to learn & use.
3. I use the full design version, called "Suspension Analyzer" which allows me to design every aspect of the car's suspension & see the 3D results.
It is more complex to use, mainly because you have to sort through a gazillion input options most guys won't use. I have found Performance Trends Suspension Analyzer is the easiest to use of the complete, 3D software brand options, but that's like saying brain surgery is easier than rocket science. It's $399 & you can get it HERE.
I am a fan of people learning this stuff, measuring their cars, experimenting with set-ups, etc ... and for that you'll want to purchase & learn the appropriate software.
For other car guys that aren't interested in doing multiple cars & just want to get their one car optimized ...
be it roll centers, steering, spring & sway bar rates or building a custom suspension ... I offer a large menu of tech services to do this for you. It's a pretty simple process and an everyday part of my business model, where I provide you instructions & a form ... you measure your car ... I input the numbers to calculate what your current set-up is ... and then use my knowledge & experience to design you an optimum set-up. I provide you with the realistic changes to make & you end up with a highly optimized suspension set-up. These services start at $39 & up. You can see them HERE.
If anyone needs help deciding on a software ... or potentially one of my tech services ... feel free to contact me & discuss.
Ron Sutton
(916) 834-8051
[email protected]
Ron Sutton Race Technology
Old 10-10-2014, 03:24 PM
Thanks Ron!
Have used the PT trial before and it was great but for a minitrucker(everyone starts somewhere) it was to much $.Was thinking of you when I said "so if I need some help I can send a file to someone". Someday I will get you to help me fine tune. I read all your posts over and over until I understand. Everyone on this site is very helpfull but your way of explaining things is eaisier for me to understand.
-Eric
