Old 09-25-2014, 05:11 PM
IndyNova's Avatar
IndyNova IndyNova is offline
Default Shifter adjustment help please
Hi guys, I have a b&m pro stick that i used with my old. 350/350 setup. I'm finishing up my 6.0/4l80 swap, and got the correct cable bracket From b&m for the 4l80 and I cannot get it adjusted correctly. I've done it exactly like the instructions say to adjust it, but it's not correct. If I set it in reverse, when I shift into low, the barrel is off by an inch or so. If I adjust the barrel for low, it won't catch any other gears. Here's the instructions that I've been going off of. Any help will be greatly appreciated!
http://http://www.bmracing.com/bmnew/pdf/9500857.pdf
https://facebook.com/Protour69Nova
69 Nova-Ridetech, LS
Old 09-25-2014, 06:53 PM
Have you removed the 'pin' that makes it a 4 speed shifter?
Old 09-25-2014, 07:07 PM
I took a look at them and it looks like the shifter may need a different gate plate? I Use a different shifter on mine that had a pin to remove as it was a ratchet type.
Old 09-25-2014, 07:11 PM
IndyNova's Avatar
I did not know there was a pin that needed removed. I assume it's on the shifter itself?
Old 09-25-2014, 07:15 PM
I think in your case its a different gate if yours is a gated shifter. You have to make the shifter hit the extra position. That would explain why its out so much.
Old 09-25-2014, 07:17 PM
Something like this. http://www.summitracing.com/int/part...0712/overview/
