Old 09-27-2014, 02:01 PM
boonedog boonedog is offline
Default What master?
Forged Narrow Superlite 4R Big Brake Rear Parking Brake Kit Product Number: 140-10093-D
Forged Narrow Superlite 6R Big Brake Front Brake Kit (Hub)Product Number: 140-10776-D
Need help choosing the proper master cyclinder going with manual brakes
Old 10-02-2014, 03:35 PM
Apogee Apogee is offline
Assuming approximately a 6:1 pedal ratio, I would run a 7/8" bore master cylinder with at least an "FF" CoF pad, although my preference would be a more aggressive "GG" compound pad like the Hawk HP Plus or EBC Yellowstuff. Would it be correct to assume that you're going to run the standard BP10 compound Wilwood pads, or did you upgrade them when you ordered your brakes? More information about your build wouldn't hurt...what's the estimated curb weight going to be on your C10? RWHP/Torque? Tires? Intended use?
Tobin
KORE3
www.kore3.com
Old 10-05-2014, 06:21 PM
Thanks for the reply Tobin I'll be in touch when I have more anwser to your questions.
