Old 09-28-2014, 11:39 PM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Need help with Wilwood caliper part number identification
Hi guys
I need to order a set of brake pads and not sure which pads I should order. I have willwood 4 piston caliper for the rear and 6 piston caliper for the front installed by the previous owner.
I have checked the caliper and could not find any label or stamp whatsoever indicating any part number.
Any input will be highly appreciated guys
72 Camaro RS:SOLD
68 Camaro:
LS6 Engine,Tremec TKO 600,5 Speed
Complete Speedtech Subframe Kit,Speedtech Torque Arm, 9" Rearend from Strange, Wilwood Brakes, Minitubbed, Hotchkis Subframe Connectors, FIKSE FM5s
Old 09-30-2014, 02:00 PM
dontlifttoshift's Avatar
I can't see the pictures.
Srsly, pics and we can help.
Donny
Old 09-30-2014, 08:24 PM
Sieg's Avatar
Sieg Sieg is offline
You can ID the caliper via pictures and specs on their site: http://www.wilwood.com/index.aspx
Old 10-01-2014, 12:53 AM
72Z/28's Avatar
I have looked up in their website and found variety of calipers. I thought the pictures were for display only and not representing the actual model
72 Camaro RS:SOLD
68 Camaro:
Old 10-01-2014, 05:29 AM
Rick D's Avatar
Rick D Rick D is offline
As Donny said post some pictures of "your" calipers and I'm sure someone can tell you what they are? Also did you try calling Wilwood??
Rick
Old 10-02-2014, 03:59 AM
72Z/28's Avatar
I have not called Wilwood yet but I a going to take some photos and post them
72 Camaro RS:SOLD
68 Camaro:
Old 10-02-2014, 07:43 AM
Sieg's Avatar
http://www.wilwood.com/Calipers/CaliperListLanding.aspx
