Old 10-11-2014, 02:21 PM
tommycomfort's Avatar
tommycomfort tommycomfort is offline
Default Aeromotive A1000 Stealth fuel cell
*** SOLD *** Item Location (City/State): Mooresville, Indiana
Price: $500 or best offer
Description:
This is the fuel tank that we have been running in our wagon for a couple of years since we installed the fuel injection system. Much more capable fuel pump than we ever needed. Just removed this tank to put the stock tank (modified with the Aeromotive Phantom Fuel System kit installed) back in. No trouble with it whatsoever. I'll even include the mounting cage we built if you like. It would be an easy fit in a 64-67 Chevelle wagon or El Camino. I would really like this to be local pickup in Mooresville, Indiana, but can ship it at the buyers expense too. Or, if you meet us by the highway on our trip to SEMA we can deliver it. $500 or best offer. Tom 317 502 7460
Summit sells it for $795.97 and this is what they have to say about it:
Capacity: 20 gallons
Fuel Cell Color:Natural
Fuel Cell Material:Aluminum
Foam:No
Sending Unit Included:Yes
Sender Ohm Range:0 ohms empty, 90 ohms full
Length (in):24.000 in.
Width (in):20.000 in.
Height (in):10.000 in.
Outlet Fitting Quantity:One
Outlet Fitting Size:-10 AN
Vent Fitting Size:-8 AN
Return Fitting Size:-8 AN
Tip Over Valve Size:-8 AN
Sump:No
Quantity:Sold individually.
Notes:Includes a 100 micron stainless steel prefilter and Aeromotive A1000 electric fuel pump built into the fuel cell.
These Aeromotive A1000 Stealth fuel cells feature a built-in Aeromotive A1000 fuel pump and a 100 micron stainless steel prefilter. They can be mounted anywhere in any car. Simply strap one of the fuel cells in, hook up your fuel line to the pump outlet and your two wires, and you're done. You won't have to search any longer for a place to mount your fuel pump and pre-pump filter. Through an innovative baffling system inside of the cells, the fuel pump inlet always has a constant column of fuel. In addition, the Aeromotive A1000 Stealth fuel cells' baffling keeps fuel at that same point, even during extreme driving conditions, making them perfect for off-road vehicles, drag racing, and even autocross and drifting. Plus, the pump is inside of the cells, so noise is drastically reduced, and the fuel pump runs cooler longer, ensuring longevity and drivability.
Additional features include:
* Available in 15 or 20 gallon capacity
* All-aluminum construction
* TIG-welded
* Flush mount lid assembly
* Two -8 AN rollover valves
* Universal 0-90 ohm built-in fuel level sending unit
* -8 AN return fitting for bypass line from the fuel pressure regulator
Tom Farrington
66 Chevelle hardtop (ours) http://www.pro-touring.com/showthrea...PT-build-(ours)
64 Chevelle 4-dr wagon (wife's) http://www.pro-touring.com/showthrea...HAUL-LONG-ROOF
The new shop build https://lateral-g.net/forums/showthread.php4?t=42857
Old 10-12-2014, 06:54 AM
Replied to all PMs.
Tom Farrington
Old 10-18-2014, 01:51 PM
Saturday bump
Tom Farrington
Old 01-03-2015, 10:08 AM
Default *** Sold ***
*** Sold ***
Tom Farrington
