Originally Posted by PoorMan
I failed to mention he did say that included the price of the engine tranny. And sticker shock made me forget that he broke it down...5K labor and 15K spent on engine and tranny. Should rebuilding and LS1 cost 15K?
It all depends on what you want.. if you would be happy with a mainly stock LS1 (for now) then you could find a clean pull out engine by shopping around. Maybe you could toss a cam in it for $400. I bought my LS1 for $2800 delivered and it included a 4L60e trans, a T56 would cost a bit more. The key is to buy a pullout engine with all the accesories and wireing harness. Then you will need the following:
Wireing harness rework = $450 from Speartech
Engine mounting plates = (not sure on a Nova.. maybe ATS or you could make some.. lets say $300)
Computer reprograme = $350
Fuel system = depends, rework the factory tank and use a regulator from '99 Vette or buy a custom tank (~$800 from a place like Ricks) and use the same regulator.
Other incidentals will depend on what you want. If you want aftermarket gauges then you will need a few fittings and the gauges. A few hours to have them installed or do it yourself after the car runs.
Oh, and you will most likely want headers. You could make the factory exhaust manifolds work on the cheap or find some. Make sure when you get the pull out engine that you get the O2 sensors.
All the rest is just fluff.. you can use your stock radiator with a little work but you will need electric fans. AFCO sells an LS1 swap radiator for about $500 and the fan/shroud for $250 or you can shop around.
Did his price include all this stuff (cooling, fuel, etc)?? I would imagine those would be "upcharges". I would say you should be able to get it done nicely for $15k or less. Most of it depends on how much you spend on the doner engine/trans.
