Old 10-28-2014, 11:18 AM
Sonar Chief's Avatar
Question GM 4l60E for Camaro swap?
I would like to know which GM 4L60E tranny has a bell housing for a SBC and the tailhousing similar to the TH400. I have a connection to get one .... just don't know which?
Any suggestions would be appreciated .... I need one that I can rebuild w/o buying parts to make work, if there is such a tranny already set up from GM.
Thanks again .... chime in!
Old 10-28-2014, 01:32 PM
Tim john--- Tim john--- is offline
I have a 35,000 mile 4L60 out of a 2004 GTO available. Completely stock, I am using the GTO engine and will purchase a T-56 Tremec in the near future. The transmission has been removed and set aside (indoors)for a rainy day, someone in need. If you are interested let me know and perhaps we can work something out that is fair for the both of us.
Tim john---
Old 10-28-2014, 02:27 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Not sure about the tail shaft.. But most of the 90's 4L60E's will work. You can tell the LS versions from the SBC versions because the LS ones are a full circle, ie. no removable inspection cover. 2 bolt holes on the bottom attach to the oil pan.
For electronic controllers I highly recommend the US Shift unit by Baumann electronics. Easy to tune & cheaper than most.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 10-28-2014, 02:32 PM
Default Thanks!
Tim john---
PM'd
-Dale
Thanks Dale ... I have seen the SBC ones then, w inspection covers. That is what I needed to know!
Monster said I needed a 1 piece pre 98 case? I wrote him back to see ...
Old 10-28-2014, 05:29 PM
Question
-Dale
Dale ... what years and models did this come in from GM?
Thanks,
Michael
Old 10-28-2014, 07:08 PM
71455Formula's Avatar
71455Formula 71455Formula is offline
LT1 Fbodies, vettes, v8 trucks(1500's).
1971 LS5 Firebird Formula with a 6 speed(Finally drivable)
2013 GMC Sierra(sold)
2000 Formula Ws6 6 speed(miss her!)
Old 10-29-2014, 11:24 AM
Smile
I called Monster Trans and he said I needed a 1 piece case outa pre 98 to mate to the first gen SBC .... found a 96 camaro 4L60E for $125. Going to go get it Friday.
Thanks for all that chimed in .....
Michael
