Old 06-07-2006, 10:30 PM
tomspo04 tomspo04 is offline
Default What Kind of Mods for a Stock 502 RamJet?
I've got a new 502 RJ that's going in my 70 Camaro and wanted to add a few ponies while it's out on the stand. I've got a set of full roller rockers that I'll intall, but does any one have any advise for other mods? The engine is new and would be fine the way it is but I fugured it would be a good time to add HP. Any suggestions would be appreciated.
Tom
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
Old 06-13-2006, 10:29 AM
MEAN LT1 MEAN LT1 is offline
What are the specs of the cam, I would probably go with a bigger cam and depending on what kind of money your looking to spend, go ahead and get the heads worked.
Old 06-13-2006, 03:01 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
If you are running the ECM that comes with the RJ, you might be very careful on your mods since it is pre-programmed and as far as I know, non adjustable. If you switch out to a different operating system, the sky is the limit on mods.
I understand they are not friendly to many changes with the built in programming.
Old 06-13-2006, 10:43 PM
morbid creations morbid creations is offline
Lightbulb
i have just the link for you... i hope it helps..
http://superchevy.com/technical/engi...c_ramjet_copy/
Old 06-13-2006, 10:48 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Cool link, thanks!
-Tom
camarorestoration.com
Old 06-16-2006, 04:57 AM
Default Great Article
I agree, great article...I was a bit surprised that they didn't get more un-sprayed HP than they did. I think that I'll eventually go with something like a FAST ECU, cam, headwork and injectors…but that’s later on. I have got a set of roller rockers that I’ll throw on before I drop it in, though. Thanks for the replies. I've been away from the computer for a while so wasn't able to give thanks earlier. Rock, thanks for posting the videos!!! NICE CAR!!! Have you been able to get on it yet?
Tom
Old 06-16-2006, 07:08 AM
Efi69Cam Efi69Cam is offline
The roller rockers won't fit under the covers without a spacer gasket.
Scoggin Dickey can get you the gasket.
Old 06-16-2006, 09:49 AM
rockdogz's Avatar
Tom
Still babying it some, want to get some miles on all the new components... But oh yeah that thing is a monster...
-Tom
Old 06-16-2006, 11:01 AM
rocketman's Avatar
Some engine builders build a Nos motor to be alittle lazy off the bottle and amonster when on it.I had a 768 in my pro mod and off the motor it was real lazy and only made 1550 put on the Nos it made well over 2400.
Old 06-17-2006, 02:29 AM
Got it cover...I've got a tall set of valve covers for it.
