Old 11-29-2014, 05:18 PM
vstol vstol is offline
Default Anyone use aluminum fuel line and crimp adapters
I'm looking for feedback from anyone using aluminum fuel lines and crimp connectors. Thanks
http://www.russellperformance.com/mc...adapters.shtml
Old 11-29-2014, 09:11 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I'm using them for an EFI setup that's been on the road for a little over 6 months (and now garaged for winter); easy to assemble; can't speak to longevity or potential for work hardening.
Old 11-29-2014, 09:36 PM
Rod P's Avatar
Rod P Rod P is offline
I have used the aluminum line and crimp connectors for 3 years now with no issues
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 11-30-2014, 05:11 AM
thanks what brands
Old 11-30-2014, 09:11 AM
Mkelcy's Avatar
I used Russell tubing and fittings. I put a short stretch of flex hose between the engine and the tubing parallel to the crankshaft just to allow for some movement.
Old 12-01-2014, 09:03 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Yep, no problem. Russell is good, also have used Fragola. Even the Summit brand isn't all that bad. Just have to make sure the aluminum is nice and straight, no large flat spots from the roller used to straighten the tubing, etc.
Just like Mike above me said, you'll always need a piece of flexible hose somewhere.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 12-01-2014, 12:41 PM
I would be skeptical to use aluminum fuel lines on a daily driver, but that's just me. I personally suggest SS line.
Old 12-01-2014, 02:07 PM
NOPANTS68 NOPANTS68 is offline
I watched a car burn at the drags trip a few years back after an aluminum fuel line cracked and split. The car rubbed the wall and bounced off enough to rupture the line at an insulated clamp on the frame. Fuel sprayed the headers and up it went. After seeing how fragile that stuff was, I went to SS AN line.
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
