Old 12-14-2014, 07:51 PM
Hotrod46 Hotrod46 is offline
Default New from Louisiana
Hello - I've been lurking for a while. I found this site while searching for suspension info and found Ron Sutton's excellent write ups. I'm not sure if my project qualifies as a Pro Tourer, though. It's an old Austin Healey based kit car from the 80's that I picked up cheap. It started as a simple rebuild, but has morphed into a full blown redesign.
I am resigning the Mustang II front suspension with my own longer control arms and narrowing the rack. The rear will be a narrowed Explorer 8.8 with a 3 link. Power will come from a 383 stroker and a T56 6 speed. The engine is still just parts right now. The suspension is under construction. I have some parts built, but I'm still working on the geometry. The downside is that it is limited on tire width, though.
Here's a pic of it before I blew it apart for the rebuild.
Mike
Old 12-14-2014, 09:24 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Always wondered what happened to those old kit cars.
I figure that there are a bunch of them hanging around, just need to get the owners to sell them for a song.
Check out these photos.
https://lateral-g.net/forums/show...ghlight=flares
This car is here in the Santa Cruz CA area. Custom suspension with one-off a-arm set-up in the front, flares and side pipes, to widen the track width and get wider tires under the fenders. Has a small block Ford. Really nice car, made the car look like a semi-cobra roadster.
The flares and side pipes really balance the look of the car and contribute to stance of the car.
DETONATOR - 69 Camaro RS
LS1 - T56 - Chris Alston Frame - 2" drop
G-Link Rear - 4.20 gears in 9" - Mini Tubs
Old 12-15-2014, 02:25 AM
Getting better rubber on the car is what started all this. Even though the car has flared fenders, the widest tires that fit are 205's. I decided to narrow the track and that snowballed into where I'm at now. If I'm going to all the trouble, I might as well make a few improvements.
Old 12-15-2014, 07:11 AM
Welcome to the site. Sounds like a really neat project. I look forward to seeing your progress. Good luck!
Old 12-15-2014, 11:03 AM
BMR Sales's Avatar
Welcome!
Old 12-16-2014, 06:36 PM
Thanks for the welcomes. I'll post some pictures as I progress.
Mike
