Old 06-12-2006, 02:34 PM
novajess1972 novajess1972 is offline
Default Replacing 4:10s with 3.73s
I have a 67 El Camino. I just dropped a 383 stroker in the engine bay, but I want to change the rear end out. The 4:10s are great for what they are intended, but I'm bigger on cruising than I am on getting out of the hole. I bought some Richmond 3:73s from JEGS. They offer 2 sets of 3:73s. I bought the ones that specify for 3-series carrier (3.07 to 3.73) but should've bought the ones that specify for 4-series carrier (3.90 and numerically higher). Is there a way I can still use the gears for the 3-series I bought in the 4-series that I have????
Old 06-15-2006, 01:10 PM
cjrolke cjrolke is offline
to my knowledge you can not do that
you could have done the opposite
i believe the ring gear is a different thickness
Old 06-16-2006, 07:06 AM
Crap! Guess I'll have to send it back and exchange for the other.
Thanks a lot for the info..
Old 06-17-2006, 09:40 AM
Steve68 Steve68 is offline
I know you can run 4 series gears on a 3 series carrier, you need the spacer, but I don't know the other way around, car Moser or another,
