Old 06-12-2006, 04:31 PM
KillaCamaro67 KillaCamaro67 is offline
Default Trouble installing DSE mini tubs.. HELP!!!
HEEELP!!
my body guy is having a hard time figuring out the proper avenue on how to get past:
1. if we have to relocate shocks.. because it we cut out the fenders the shocks normal bolt point will be gone.
2. if we have to relocate leaf springs
3. can we run stock tailpipes.
4. if it can run stock gas tank.. because if we relocate the leafs it will get close to the tank.. no clearance..
i just got the tubs and i know i need to get some other parts.
what all do i need to complete it?
much thanks for the help yall!
Old 06-12-2006, 04:54 PM
mdprovee's Avatar
mdprovee mdprovee is offline
I had mine done bt Meanstreets Performance and Vince has posted some pictures.
http://hometown.aol.com/gumbydmit22/mpcamaro.html
(Yes DSE sells a new crossmember, or you can make your own.)
(yes if you want to get a 315 tire in the fenders)
(not sure I am not at that point yet)
(You will need a narrowed tank to fit between the relocated springs.)
If you look at the DSE kit those are the things you will need, or again you can make your own.
Mike
