Old 12-27-2014, 12:09 PM
71455Formula's Avatar
71455Formula 71455Formula is offline
Default T56 Speedo.
What is everyone doing to run the factory speedometer with the t56's? Or what adapter are you using? Thanks in advance.
1971 LS5 Firebird Formula with a 6 speed(Finally drivable)
2013 GMC Sierra(sold)
2000 Formula Ws6 6 speed(miss her!)
Old 12-27-2014, 04:15 PM
You can easily get your speedo changed over to electronic. I believe Gaugemarks is one of the companies that can do it. I would recommend this over having a cable coming into the car.
Actually, that may not work. I forgot you were staying with the pontiac motor. Sorry.
Old 01-02-2015, 10:53 AM
Anyone else?
Old 01-02-2015, 11:00 AM
Vince@Meanstreets's Avatar
For factory cable speedometers we use the cablex unit from Abbott.
Very simple to hook up.
http://www.abbott-tach.com/cablex.htm
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
