Old 12-29-2014, 09:03 AM
samckitt's Avatar
samckitt samckitt is offline
Default I need a Maxi fuse terminal for GMPP fuse box.
Anyone know where to get one? I am adding a PWM circuit & want to add a Maxi fuse to the existing GMPP fuse box. I need this terminal for 10 or 12 gauge wire:
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-29-2014, 11:23 AM
Vince@Meanstreets's Avatar
I got this link from Mark a while ago, you'll have to do a search for it though.
https://www.eficonnection.com/eficon...px?ItemId=1126
GM search prox
https://www.eficonnection.com/eficon...nalSearch.aspx
might be it....
https://www.eficonnection.com/eficon...px?ItemId=1160
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-30-2014, 07:02 PM
samckitt's Avatar
I was at the junk yard today looking for some other stuff & came across a Cadillac that had a fuse box for the Max fuses only. I removed a couple terminals out of it & used that to add another circuit to my GMPP controller harness fuse box. I also discovered that the GMPP harness fusebox was used on full size GM trucks, Suburbans, & Tahoes in the mid 90's.
Here is pic of one I found in a Suburban:
On my fuse box I cut the bus bar that feeds power to the Max fuses so I could pass the wires through the bottom of the box instead of routing it outside like it came from the factory. I moved those fuses up 2 spots & added the one for the fans. I found a Max breaker at the junk yard. I wrapped the wires with a zip tie to keep them from rubbing the buss bar where I cut it.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-30-2014, 07:06 PM
samckitt's Avatar
GM search prox
might be it....
I think you are right, those look like the ones for it. Thanks.
Scot
86 Monte SS
LS2/T56 Magnum
Old 12-31-2014, 08:20 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
I didn't look at the other links, but just for future reference:
They're Delphi connectors, available from Mouser.com
12092444-L = 10-14 gauge wire
12092445-L = 8-10 gauge wire
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 12-31-2014, 06:24 PM
samckitt's Avatar
-Dale
Thanks Dale, I went to the dealer today to pick up something else & gave him these two numbers. He looked them up & they were no longer in the system & not replaced with anything. So we went back to the box/drawers with all the terminals & found the number there. I got two of them real cheap, for nothing
Scot
86 Monte SS
LS2/T56 Magnum
