Old 01-04-2015, 06:37 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Brake line straightening
What are you guys using to straighten brake and fuel lines? I thought about making a tool as I've seen a few guys build them and they seem to work pretty good. I'm thinking now that I'd rather just buy a tool as between the Bronco and the car I will be running 3 different line sizes and would rather not have to be adding washers to make the gap right. I was thinking of getting this tool from Brakequip as it looks like it will easily adjust to the different sizes.
http://www.eastwood.com/tube-straightener.html
Anyone have any experience with this tool? Thanks.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 01-05-2015, 06:23 AM
Hey mike someone had plans on here to make your own straightener with patio door rollers and 3 "angle...maybe check pro-touring..in the fabrication forum
Old 01-05-2015, 09:48 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I made my own using patio door rollers and angle, it worked great for 3/16 brake line but not so well for 3/8" fuel line.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 01-06-2015, 08:03 PM
scherp69's Avatar
I've looked at a few different design that guy have built. They look quite simple to build, but to change tube sizes you need to start adding washers to get the spacing. I'll have three different sizes and I like the idea of the adjustablility of the Brakequip one.
That's what I was worried about. I want to buy one unit that will work with brake and fuel line.
Mike
New Gen Splitters
LS3 and TKO600
Old 01-07-2015, 08:40 AM
dontlifttoshift's Avatar
Buy it straight, then you don't have to straighten it?
Donny
Old 08-05-2015, 08:38 PM
redss86 redss86 is offline
Where can you buy a 20' piece of straight line? Let alone shipping?....just saying. I have been contemplating building one as well. Just haven't dug into researching it more, yet. Looks like a simple enough design. If I do something. I will share my info.
Old 08-05-2015, 09:04 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
I saw this post just the other day: http://www.nastyz28.com/forum/showpo...&postcount=242
Scott from NJ
Old 08-05-2015, 11:49 PM
Vince@Meanstreets's Avatar
I made one but wouldn't do 3/8 line so I just bought the unit from Eastwood. Works on 3/16 to 1/2" lines. I havent tried it on the 1/2" yet.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 08-06-2015, 07:05 AM
What car are you working on that you can get a 20' piece of brakeline or fuel line in? If you can get from the master cylinder to the rear end in one piece that's awesome but I will just put a union in the middle and finish it in half the time.
Donny
