Old 06-14-2006, 01:03 PM
AAW's Avatar
AAW AAW is offline
Supporting Vendor
Thumbs up New High Amp Alternator Installation Kit - AAW
American Autowire is pleased to announce the newest addition to our product line – the High Amp Alternator Installation Kit.
The High Amp Alternator Installation Kit provides 10 ft. of large 8 awg power wire with fusible link for circuit protection and a ring terminal pre-installed. The kit also includes the necessary connector and wires for GM "SI" series three wire alternators as well as an alternator terminal boot and loose piece terminals and connectors for easy installation.
The High Amp Alternator Installation Kit can be used on either one (1) wire or three (3) wire alternators.
The High Amp Alternator Installation Kit is part number 500875 and is available immediately.
$25.00
Thank you!
Old 06-14-2006, 02:30 PM
Speedster's Avatar
Speedster Speedster is offline
T-
Just one question: Is 10 feet long enought to get from the alternator to the trunk mount battery or is this made to go to a terminal block on the firewall ?
Also, do you have a good, compact high power alternator you would recommend ? e.g. MSD, Powermaster, etc. I am looking for the smaller diameter one with the most amps. I know you can get 200 amps from one of those big LT-1 style units, but that is just not feasible.
TIA
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
Old 06-15-2006, 06:06 AM
AAW's Avatar
AAW AAW is offline
Supporting Vendor
Originally Posted by Speedster
T-
TIA
Bruce
Good question(s)! Actually you have a few questions in one...
This kit was designed to attain the power buss from the starter solenoid or a battery (+) terminal block located on the firewall. It was not designed for rear trunk power sourcing.
Because the wire is only 8 gauge, we would need to do additional engineering to spec the correct gauge of wire for a trunk mount to eliminate voltage drop which is a concern with extended wire applications.
Regarding the alternator, PowerMaster and MSD are reputable companies which we interface with on a regular basis. The best alternator deal might come from Jeg's who handle both these product lines, so contact them for pricing - or go directly through Prodigy to get pricing.
I hope this helped...let me know if you have additional questions.
Theresa
Old 06-15-2006, 06:09 AM
Bruce, Lisa can get you a 160AMP MSD, probably the most umph from a small alternator. In the shop we use a lot of Tuff Suff 140AMP that have been testing at 150AMP
Old 06-16-2006, 05:28 AM
Speedster's Avatar
Thanks Frank. I will check with Lisa before I buy.
-Bruce
Project "Freebird"
Dyno Video
Project Rides:
2007 Magnum
Old 06-16-2006, 05:29 AM
Speedster's Avatar
Originally Posted by AAW
Bruce
Theresa
Thanks T !
-Bruce
Project "Freebird"
Dyno Video
Project Rides:
2007 Magnum
