Old 01-12-2015, 09:30 AM
GMTILT's Avatar
GMTILT GMTILT is offline
Default 69 Camaro Tilt Column with High beams
Here is the 69 Camaro tilt that we build with the high beams on the turn lever, this column lets you take the button off the floor and use the turn signal lever as the high beams switch, it uses the same plug from the floor to the side of the column.
the lower neutral lever is shaved off and the column is locked in the "park" position, this one is done in satin , you can have polished at same price, this column is 450.00 shipped
http://gmtilt.com/
