Closed Thread
Old 01-19-2015, 06:14 PM
4mm 4mm is offline
Default DSE SBC/BBC Subframe Stands & Mounts-Cheap
DSE stands and mounts for the DSE hydroformed subframe. DSE sells these for over $200.
They are slightly used. Will sell for $65 shipped within the CONUS.
Thanks.
Old 01-19-2015, 07:49 PM
4mm 4mm is offline
They are slightly used and were removed from my former 5 yr old DSE 68 Camaro to install an LS3.
Old 01-20-2015, 11:48 AM
FYI, all you would need are the adapter plates to run an LS. Good deal, wish I had a need for them.
Old 01-20-2015, 02:20 PM
ADiCarlo ADiCarlo is offline
Are these standard position or set back?
Old 01-21-2015, 06:47 AM
custom 68 custom 68 is offline
These look similar to factory. I have a 71 Camaro with the factory cross member and these look like they should work. Do they sit flat?
I assume the motor mounts are poly?
I am very interested.
Dave
I had posted this over on Pro-touring site but had not seen these here.
Old 01-21-2015, 02:09 PM
4mm 4mm is offline
Sorry for the delay in responding. I didn't receive any notifications. They are sold. Thanks Dave.
Closed Thread
