Old 01-26-2015, 11:50 AM
UMI Performance UMI Performance is offline
Talking UMI Performance New Product- Anti-Eccentric Toe Rod Washers for the 10-14 Camaro & G8
Anti-Eccentric Toe Rod, Lower Control Arm Washers for the 5th Gen Camaro & G8
P/N- 2518
Priced at $12.99
UMI’s 2518 anti-eccentric washers are designed to prevent unwanted alignment changes in your 5th Gen or G8 rear suspension. The 3/16” thick laser cut washers fit in the exact factory location and provide a stable location for UMI (or other aftermarket) adjustable toe rods or adjustable rear lower control arms. Racing stress or hot street cornering can move the offset factory washers causing rear alignment issues. UMI’s 2518’s are a great way to increase rear suspension reliability. Kit includes 4 laser cut black zinc coated washers, anti-eccentric washers should only be used on adjustable components. P/N 2518 fits rear toe rods or rear lower control arms. Four washers will work on a pair of toe rods or control arms. 100% manufactured, tested and raced out of Philipsburg, PA – USA.
Website Link Here- #2518
