Closed Thread
Old 02-01-2015, 10:40 AM
69dragracer 69dragracer is offline
Default 68 Camaro -LS2, TR6060, Ridetech, Vintage Air
Item Location (City/State): Huntsville, AL
Price: $59,000
Description:
Up for sale is my 1968 Camaro. It’s a fresh build with 830miles on it as of 2/1/15. Other than the engine and transmission, everything else was new when the car was built. Here are some highlights on the car, feel free to pm me or call/text for more info on the car (256-2eight2-five004). I have posted more detailed pictures of the car on photobucket, see link below.
http://s1361.photobucket.com/user/ad...20Cyber%20Gray
Body:
Car was painted in Feb-2013. Paint is GM Cyber Gray Metallic, painted with Dupont Chormabase product. Prior to paint car had both quarters, tail panel, door shells, both fenders, trunk pan, partial floor, and hood replaced. As you can see most of the exterior metal on the car was replaced. Car still has the original VIN tag on the dash and body tag on the firewall.
· All new glass in car, new window regulators and door hardware as well
· Global West subframe connectors
· HID headlights , LED taillights, and LED side marker lights
· New wiring harness throughout car, factory style harness and fuse block
Suspension:
· DSE upper and lower control arms, QA1 Front Coilovers, Hotchkis Sway Bar
· Global West 600 series steering gearbox, quick ratio
· CPP C5 style spindles with C5 bearing packs
· C5 Front calipers on 13” drilled/slotted rotors
· Rear is Ridetech 4-link with Ridetech non-adjustable coilovers
· Rear brakes are 11” rotors with GM metric calipers w/ integrated parking brake
· Vintage Wheel Works wheels, 17x8 Front and 17x9.5 Rear. Nitto 555 tires with 245 on front and 255 on rear.
Drivetrain:
· 2006 Corvette LS2 engine with 42k miles. Has an FAST 102 intake and unknown cam swap done prior to me buying. I tore the engine down to the shortblock for inspection prior to installing it. I put a new harmonic balancer, ARP balancer bolt, GM head gaskets, and ARP head bolts on the engine. Also replaced the stock oil pan for an AutoKraft oil pan for clearance
· Dynatech LSX headers with 2.5” PYPES stainless X-pipe and Stainless Dynamax mufflers
· PSI conversion harness, ECM reflash with HP tuners
· 2012 Camaro TR6060 6 speed transmission, Mcleod custom shifter, and DSS 3.5 aluminum CV joint driveshaft
· Ford 9” rearend housing from Quick Performance, 31 spline axles, Currie Nodular 3rd member with 3.50 gears and trac loc posi unit.
· Fuel system is a Tanks Inc tank with internal sump and Walbaro 255 in-tank pump.
Interior:
· Autometer Carbon Fiber series electric gauges: Fuel, Speedo, Tach, Voltage, Oil Pressure, Water Temp
· Vintage Air Gen IV Heat/AC System and Vintage Air 3 Knob billet controller
· Front seats are Corbeau Sport Seats in Black Leather, Rear seats are GTO rear leather seats modified to fit.
· Morris 3pt seat belt conversion.
· Deluxe Door Panels Front and Back
· 2012 Camaro Center Console
· Pioneer Head Unit with Bluetooth and handsfree, Pioneer 6x9 speakers mounted in rear deck and Pioneer 4” speakers mounted in kick panel.
Last edited by 69dragracer; 02-05-2015 at 08:17 PM. Reason: Fixed photobucket link
Old 02-11-2015, 08:01 PM
Back to the top
Old 02-23-2015, 09:59 AM
Car is sold!
Closed Thread
