Old 02-01-2015, 12:19 PM
John510's Avatar
John510 John510 is offline
Default I need help choosing Subframe connectors.
I am in the need of some subframe connectors. Preferably some that bolt on since my car is already done and I do not want to weld some in. I have a Chassisworks G-link rear and a Speedtech sub in front. Anyone know of a simple bolt on one I can use? Thanks
John
[SIGPIC][/SIGPIC]
Old 02-01-2015, 05:01 PM
Rod P's Avatar
Rod P Rod P is offline
I used Hotchkis connectors and bolted the front and welded the rear
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-02-2015, 07:38 AM
Musclerodz's Avatar
Hotchkis probably fit the tightest for a bolt on sfc
Mike Redpath
Musclerodz & Customz
facebook page
Old 02-02-2015, 09:16 AM
dhutton dhutton is offline
Edit: I was dead wrong on the material thickness. Never mind...
Don
Old 02-02-2015, 10:28 AM
John510's Avatar
Anyone know if the competition engineering ones are any good?
[SIGPIC][/SIGPIC]
Old 02-02-2015, 10:37 AM
Richio1's Avatar
Richio1 Richio1 is offline
I used the Hotchkis as well. What does CA Chassis Works offer?
In looking at both websites; DSE and Hotchkis both use 120 wall steel.
Jeff
Lateral-g Feature - https://lateral-g.net/forums/showthread.php4?t=44186
Build thread - https://lateral-g.net/forums/show...ght=brownstone
Special thanks to Matt's Classic Bowties along with
Old 02-02-2015, 10:56 AM
Revved's Avatar
Revved Revved is offline
Originally Posted by dhutton View Post
I installed Hotchkis subframe connectors on a 68 Charger. I was unimpressed by the gauge of the steel compared to DSE subframe connectors for example. It was quite a lot lighter gauge material. It seemed to me that they were more for show than go.... I would research the material before investing in their Camaro offering.
Don
Is Hotchkiss just going in the toilet? The 70 Chevelle I rebuilt had a Hotchkiss supsension under it when it came in the door and beyond fixing some geometry issues I didn't need to mess with it. On the road trip out to Miami beach the rear springs sagged over an inch so I swapped them out when when we got down to FL. The car came back to me a few weeks ago to clean up before taking it to auction and the ride height looked fine. In the hundred or so miles I put on it road testing the rear springs sagged again. Talking to a buddy that has a primarily GM shop he said he has a shelf full of Hotchkiss take out springs that have done the same thing... they will just randomly sag. Since the car didn't sell I'm going to change it over to coilovers.
-Sean
Comp Performance Group
Business Development Manager
1970 Chevelle I built years back as a Lat-G Feature https://lateral-g.net/forums/showthread.php4?t=43116
Old 02-02-2015, 11:58 AM
Vince@Meanstreets's Avatar
Garbage, go with the hotchkis for the best ground clearance, material is fine for what it does.
DSE would be a better bet but only a mad man would do the install after all that crazy detail work you have in that CAmaro.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 02-02-2015, 12:32 PM
Interesting, I am fairly certain the Mopar ones were much lighter.
OK, I checked and they state .120 wall for the Mopar ones. I need to retract my statement.
Don
Old 03-10-2015, 06:29 PM
Nativefx Nativefx is offline
Anyone know if these Pro-touring F-Body ones are any good? I'm looking for my 69 Firebird and I plan on welding them in once i get the ride height set on my Ridetech AirRide setup.
http://www.pro-touringf-body.com/cha...omponents.html
