Old 02-06-2015, 09:33 AM
UMI Performance UMI Performance is offline
Talking UMI Releases New Product- C5/C6 Front Brake Conversion Kit for the 78-88 GM G-Body
C5/C6 Front Brake Conversion Kit for the 1978-1988 GM G-Body
P/N 304647
Priced at $469.99/kit
UMI’s 304647 hub, bearing and bracket kit adapts C5 or C6 brakes to your G-body Pro-Tour machine. The 3046 laser cut bracket bolts to the spindle and properly locates the C5/C6 abutment bracket and caliper. The Made In USA aluminum face mount hub along with premium bearings and seals completes the installation. The hub features 5 x 4-1/2 and 5 x 4-3/4 bolt patterns and is intended to face mount the C5 or C6 brake rotor in exact factory location (front track width is unaffected). The kit includes premium bearing cups and cones along with the correct rawhide seal for great performance and reliability. The 304647 is the choice for UMI’s Green Machine and has been thoroughly tested to withstand road race and auto-x competition. 100% manufactured in USA as well as tested and raced out of Philipsburg, PA – USA.
P/N 3046- C5/C6 Front Brake Conversion Brackets Only
P/N 3047- C5/C6 Front Brake Conversion Hubs & Bearings (No Brackets)
P/N 304647- C5/C6 Front Brake Conversion Hubs, Bearings & Brackets
P/N 304647- Complete Kit
P/N 3046- Conversion Brackets Only
P/N 3047- Hubs and Bearings, No Brackets
Old 02-25-2015, 06:16 PM
warriorridge warriorridge is offline
Will the brackets work on the 2wd blazer spindles as well?
Old 02-26-2015, 07:08 AM
Unfortunately these are designed for the g-body spindle only.
