Old 06-17-2006, 09:53 AM
Datsbad's Avatar
Datsbad Datsbad is offline
Default Do Not Buy Ram Clutches
Well after 600 miles the clutch started showing signs of slipping. at 1400 miles its toast.
Ram said send it back . when they looked at it they were clueless on what was wrong. They decide to send my old pressure plate back and a new disc. They also said to try to remove the shim , well that didnt work , so i pulled it again and put the shim back in . still does not work .
Pull the trans again and notice the clutch disc is bent . I call them back . They act as if this is my first clutch install and tell me i bent it when i assembled it and that it was not lined up right . My response was , I used the clutch alignment tool you provided so how is that possible?
Needless to say , Ram is not willing to help at all .
I know alot of us on here dont like Ram, but for those people who are considering them, STAY AWAY .
It a shame a simple thing of sending me another disc and i was willing to sendback the bent disc , they wont do .
I have delt with many companies during the build of my car . In a month or 2 it will be in a featured add in HOT ROD. None of the companies i used gave me bad service like them (well maybe another sponsor on here also )I will be sure to let everyone know my trouble with them
""DEMON"
6.1HEMI/TKO 5 SPEED
CCW Black edition/BFG tires
Mini tub/AIR Ride
RMS Suspension
CURRENTLY FOR SALE !!!
Old 06-17-2006, 11:43 AM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
I have had problems with their products also. I originally had a 910 VDS system and it started to slip very quickly, so i went to the 980 and that also started to slip. I never delt with customer service b/c i installed it myself so theres no chance in hell they will help me. But needless to say i will not be buying any more of their products.
Kyle
Old 06-17-2006, 01:24 PM
rocketman's Avatar
I have never used one of there street clutches,But used the 3 disk race in my pro mod with no problem.
Old 06-17-2006, 01:32 PM
Datsbad's Avatar
I did not post this for a poll on who's clutch works and who's doesnt. I am simply trying to prevent someone from going through what i did .
if yours works , great
on the other hand , i have heard many times now that there street stuff they dont put much effort into it to make things right like this scenario. imagine that !
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 06-17-2006, 03:07 PM
68protouring454's Avatar
poll or not you think a street clutch to work behind a 600 hp small block??
step up to a twin disk or a spec, i am sure you have been on ls1.com and others, ram is for 300 hp drivers
Old 06-17-2006, 08:20 PM
Datsbad's Avatar
[QUOTE=68protouring454]poll or not you think a street clutch to work behind a 600 hp small block??
step up to a twin disk or a spec, i am sure you have been on ls1.com and others, ram is for 300 hp drivers[/QUOT
when the same clutch I am using is in 700+ street cars I thought i would be fine .
On LS1TECH there are many complaints for Ram and more so on SPEC .
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 06-17-2006, 08:30 PM
Unhappy part number would help
what part number was it,
jake
Old 06-17-2006, 08:34 PM
Datsbad's Avatar
I will check , dont remeber right now but I think it was a 910 disc
""DEMON"
6.1HEMI/TKO 5 SPEED
Mini tub/AIR Ride
RMS Suspension
Old 06-18-2006, 10:31 PM
ohcbird's Avatar
ohcbird ohcbird is offline
OMG- The line of complaints about clutches on LS1tech.com could go around the planet! It always goes like this: Mcleod/Spec/RAM/Textralia is great! evrybody buys, two guys have probs, then alot of them jump on the bash-wagon...
Sorry man- didn't mean to steal your thread. I feel your pain. Sme companies just don't get it, do they?
Old 06-19-2006, 08:07 AM
Payton King's Avatar
Default not that it helps
get a textralia. Customer sevice is first rate. I cannot comment on the clutch other than I have one and can;t wait to try it out.
